Find solutions to your computer repair questions.
Install driver to show hardware
Hi, I deleted the partitions when I reinstalled Windows
and now a window pops up telling me that I need a storage driver
. How can I solve this problem?
ps. I apologize for such photos, I decided to translate them to make it clearer.
Score 1
7 Comments
@nick what do you make out of this?
by
I can provide more information if you need it.
by
@catharsis71058
What is the make and model number of the PC or motherboard if a custom build and also the make and model number of the HDD or SSD drive?
by
The motherboard B450M DS3H
hardware disk toshiba hdwd110
ps. I hope I wrote it clearly, since I use a translator.
by
@catharsis71058 I was able to figure it out.
by
Show 2 more comments
Add a comment
1 Answer
Chosen Solution
Are you using a RAID card or anything like that? If you are a lot of them need drivers you inject during the installation process or the media. If not something about how the drive was formatted is throwing Windows off.
If the computer does not have a SoftRAID or RAID card installed/enabled, you may need to erase the drive to the point it is factory blank (RAW) to fix this. This guide covers the process using Parted Magic but any tool with ATA secure erase support will also work: Diagnosing and Erasing Hard Drives
DBAN also works, but it takes hours (IDGAF if you do firmware OR DBAN, it's the same grueling wait). That said, if you need to get the drive back to a state it is RAW formatted, a quick DBAN erase will do the same job for free: https://dban.org/
Give it 24 hours - I HAVE HAD TO WAIT 8.5-9 HOURS ON 750GB 5400 rpm LAPTOP DRIVES. Every time beyond 500GB, I have put the machine on the bench, go to sleep when it's late, and return to it later.
Score 1
1 Comment:
@nick hi, thanks for your reply, but I don't understand computers and I haven't figured out how to solve this problem. if it's not difficult, you can write step-by-step instructions and I will be very grateful to you.
by
Add a comment
Add your answer
catharsis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 670
