The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
782 Questions View all
Possible Ylod, is a hard drive copy possible?
YLOd even though ive only seen it once. i power on the system, it runs for two seconds then goes to a blinking red or solid light... i did see the yellow light today though.
I want to know if i can just get the HD and the game out and copy the game info to a new hd/ps3 system?
Score -1
2 Comments
YLOD fix worked!!!! i apparently have an older version than the kit goes, but i know enough and the directions are close enough! just gonna keep that usb save backed up so i dont have to worry about the fix again for a while!!!!
by
Woohoo, EXCELLENT. GREAT JOB....
by
Add a comment
1 Answer
Chosen Solution
douglas, if you have a working PS3 your could do this "Once you have your upgrade drive, the next step is to back up the data on your current PS3 hard drive to an external storage unit. You can skip this step if you aren't attached to your music, videos, and game saves, but most of us will probably want to save all that information. The PS3 has a built-in software backup utility that can copy the PS3's hard-drive contents to an external storage device, such as a USB thumb drive or a memory stick." It is not possible to copy/clone your HDD since your HDD wont be read by either Linux, Mac, or Windows. The HDD is in a format which is specific to the PS3, its not FAT32 so it can't be read by any PC. The data recovery or HDD utilities might detect the HDD,however you won't be able to view or recover any data. I am sure you also know that the HDD is specific to the PS3 which formatted it, so if you were to put it in a different PS3, it would automatically format it. If you have a working PS3 you can always just update the new console by connecting a ethernet cable to the new console and the other end to the old console then go to system settings on the new PS3 and there's a option Data transfer utility press on that and it should say you will use this feature. To transfer (copy or move) data that is saved on one PS3 system to the other PS3 system carefully read the following information and then select (ok) it will take you step by step from here. More about that on here, here and last but not least, on here. Your best bet might be to try to fix your PS3 with this kit. Hope this helps, good luck.
Score 1
2 Comments:
Yes i think i am going to have to fix it first, then im gonna back up all my save games on a usb drive or something and get a new ps3... thanks for your help.
by
Thanks for accepting my answers. Yes, I do believe that this would be a good way of doing it.
by
Add a comment
Add your answer
douglas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,690
