A HD pocket camcorder to compete with Flip mino/ultraHD. Many view the Kodak Zi8 as having a better set and a camera worth considering more then the Flip.
Why does the camera run down in ten minutes?
I charge the camera - with several new batteries - and it runs down within ten minutes. How can I fix the charging mechanism?
1 Comment
I have tried four new batteries, and two new battery chargers - and also charging it from the computer.
by
Add a comment
1 Answer
Chosen Solution
Because the battery in your device has aged, if possible, you can replace the camera or buy a battery to replace it
2 Comments:
by
@jmartz42667 Fast power consumption solution: Turn off WIFI: WIFI function can be turned off when not in use to reduce power consumption. Adjust backlight and warm light settings: Reducing backlight and warm light can lower power consumption. Waiting for the download and indexing process to complete: After the device completes the download and indexing process, power consumption will return to normal
by
Add a comment
Add your answer
jmartz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 90
