The Chevrolet Silverado is a line of trucks under the Chevrolet brand and manufactured by General Motors. Mechanically, the GMC Sierra and Chevrolet Silverado are identical.
How to rewire fuel tank pressure connector
How to rewire fuel tank pressure connector?
A rat chewed through the cables.
Should I use a butt connector with solder or something else ?
2 Comments:
I'm glad you know what you are talking about. I,m betting no one else does.
by
@bryan52849 rephrase your question. You ill need to let us know the exact year and engine size for your pickup. Then you need to tell us what is wrong with it and you need to tell us what you have already tried and checked. Your current question is not clear. at all. Nobody will know what you are referring to as a fuel tank pressure connector
by
Add a comment
1 Answer
@bryan52849 I would use some butt connectors and after crimping project those with either some electric tape or some heat shrink. You just want to make sure that you keep possible corrosion to a minimum.
Add a comment
Add your answer
Bryan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 59
