Xiaomi Redmi Note 11 4G Released 2021, December 01 181g, 8.9mm thickness Android 11, MIUI 12.5 128GB storage, microSDXC
How to fix when your phone cant touch
How to fix a phone when you cant touch
Score 1
Add a comment
Most Helpful Answer
@kyelerw I think you missed the point of the post; my reading says the digitizer has failed, not the display.
@princemharb6163 Most Android phones will automatically recognize a wired mouse when it's plugged into the USB port, and you can use the mouse in lieu of a working touch screen. I've done that on my Google Pixel when it would not respond to the touch screen; that allowed me to reboot the phone; in my case that was all it took, but if your digitizer has failed completely you'll need to replace the screen to fix it.
I just used an old school Logitech wired USB mouse with a cheap USB-A to UBS-C adapter. Once plugged in, a mouse cursor will appear on the screen and using the mouse you can click anywhere you would normally touch.
Score 1
Add a comment
You can use software like AirDroid to remotely control your device. If the touchscreen still works, but you can't see it, you can use volume shortcuts to activate feedback. You can also plug get an HDMI converter and plug your device into it and connect it to a monitor to see what is supposed to appear on your screen through the monitor.
Add a comment
Add your answer
Prince mhar blantucas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 31
All Time: 267
