Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Salvage an iMac as an external screen for MacBook
I have a 2016 27" iMac. Hardly used this machine at all. Suspiciously, immediately after a software update, it stopped functioning - won't even boot up. Apple says its a hardware issue. I don't see how. But anyway, I now have a very expensive paperweight.
I asked apple if I can at least use it as an external screen and they said no - not this model (I don't get it).
Any workarounds? Seems like such a waste for a nice retina display.
Thank you for sharing any insight.
Add a comment
1 Answer
Well... there are kits which allow you to replace the guts and with just the display make a nice external display if that is what you want.
It maybe possible to fix your system, the So called Apple service genius's will often try to convince you a newer system is better. Truthfully for some you just need the old to work as you real don't need the better performance, besides it's only now the M series graphics are better that the AMD GPU's Apple used in this series.
You'll need the tool and adhesive strips to put the display back in either way you go iMac Intel 27" (2012-2019) Adhesive Strips
Just follow this guide iMac Intel 27" Retina 5K Display Logic Board Replacement to Step 18. Then using painters tape place a strip at the bottom creating a hinge and then at the top create two sling straps on the top sides so the screen can swing out about 3" as we will want to place the system upright and look at the onboard diagnostic LED's
Let us know from left to right facing from the front, let's see why the system isn't working.
These replacement foam adhesive strips secure the display compatible with the A1419 model 2012, 2013, 2014, 2015, 2017, and 2019 27 inch iMac and the A1862 iMac Pro.  EMC 2546, 2639, 2806, 2834, 3070, 3194, 3144. Image
Product
$29.99
Add a comment
Add your answer
armen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 86
