Repair guides, disassembly information, and troubleshooting for the Logitech M185 compact wireless mouse. Identifiable by part number (P/N) 910-002225.
My scrollwheel doesn't scroll really well (ig it's called jittery)
Hi
so whenever i scroll up for example, the page instead of going up normally, it "jitters", aka scrolls down for a bit and then up, and this happens multiple times
sometimes a slight movement in the wheel will cause it to move a lot, more than normal scrolling
Add a comment
1 Answer
It is problem with scroll encoder. In my mouse is used Kailh 8 mm. high.
https://www.aliexpress.com/item/10050075...
Best way to replace. Not expensive and buy 2 for the future Better with red core.Temporally You can clean and lubricate after carefully dissemble encoder with spray for electronic contacts or last resort isopropyl alcohol, WD40
Add a comment
Add your answer
TheCube will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 186
