Repair, disassembly, and troubleshooting information for the Infinix Smart 7 Android smartphone family, including Smart 7 HD model Infinix X6516.
My phone screen sometimes it's difficulty to touch
Especially the right side of the screen become difficulty to touch, fist time I think there's a problem to screen. I restarted my phone then it becomes good but the problem return
Score 13
2 Comments
It restart on it self
by
Add a comment
Most Helpful Answer
Display hit problem
Score 3
Add a comment
When IAM play free fire game my phone is very hang issue
Score 1
Add a comment
The Infinix Smart 7 does not have a specific screen calibration setting like some other devices. However, you can troubleshoot issues with your phone's touchscreen by removing the screen protector and cleaning the screen, which might improve touch sensitivity. If you're experiencing ghost touch issues (where the screen seems to register touches without you touching it), you can try gently bending the opposite edges of the screen to relieve pressure on the digitizer.
This video might also help.
Add a comment
Yes also even restart it self
Add a comment
Your phone is likely having a touchscreen responsiveness issue because the problem goes away after restarting but keeps coming back. This usually happens due to a software glitch, a failing touch digitizer, or interference from a screen protector, case, heat, or moisture. Restarting temporarily fixes system errors, but if the right side of the screen continues to be difficult to touch, it may indicate an early hardware problem. You should try removing the screen protector and case, cleaning the screen, updating the phone’s software, and checking if the issue happens in Safe Mode. If the problem still occurs even after these steps, it is most likely a hardware issue, and the screen may need to be checked or replaced by a technician.
Add a comment
Not like that
Add a comment
You need to change the screen
2 Comments:
I need to fix my Levi's mobile phone. It needs a screen protector, motherboard, and many other things. Its button is broken.
by
just now by krkr memi Edit Delete
by
Add a comment
Charging system
Add a comment
Display lagging
Add a comment
Add your answer
Fabiana Samweli will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 151
All Time: 1,583
