Released in 2017, the Dell Vostro 15 3568 is a business-oriented laptop with an Intel processor and optional AMD graphics card inside. It has a 15-inch screen with a resolution of 1366x768 pixels.
How to make a Laptop run like a Desktop?
I have a Dell Vostro 15 3568 Laptop for the past 8 years. Have changed the keyboard and upgraded to an SSD through an external local vendor before 4 years. Before 2 weeks my laptop tumbed down on the floor making the external keyboard (usb) crashing into its screen damaging its display. Succesfully seperated the damaged screen and ordered a new display by referencing the part number of the screen. It look almost 10 days for the newly ordered screen to arrive. In the mean time, I had my damaged screen intact and accessing my laptop to an external HDMI Monitor. Everything was fine until I decided to remove the old screen from my laptop by myself. I don't know what went wrong but my laptop was turning off exactly after a minute with a beep. I assumed that, Some PC makers restricted the machines with some mandatory connections to pe present. Soon my new Display arrived. I connected everything and my laptop is fine for the first run with the new display but from the second time (after fitting the screen inside the chassis) the new screen also started showing grains everywhere. I seriously still doubt that the current problem is not display but some cables related. So I thought of unplugging the display and fiting it again. Unfortunately., The cable got de-soldered on my hands. It' a 30 pin Full HD. I gues Totally I need to replace 2 cables which I removed from the laptop. One is the 30 pin Full HD cable and other is the power cable where the WLAN intel chip was also soldered with which goes to the laptop screen. I thought the second cable is the power cable to display. Now, my Laptop is not turning on. What to do? Please Help. Thanks.
Photo attached...
Update (04/11/25)
10 Comments:
Guys. Please Help. I am in a Digital SOS situation. It's been 2 weeks after I used a computer. How many days I have to survive typing in a mobile phone. Fingers hurt. Please reply. Thanks.
by
Hope someone will answer soon. Please consider and Kindly do the needful.
With Hope,
Prabhakaran
by
@prabhakarank which cables? I see that your display cable is falling apart. That is something you definitely need to take care off. The Del part number for that is 54YNP, 054YNP and it is the same cable that you would use for the
-Inspiron 15 (3565)
-Inspiron 15 (3567)
-Vostro 15 (3568)
This "new screen also started showing grains everywhere" can come from the display cable. I am just confused on what you did after. Was the power disconnected? Did you disconnect the battery? Under what circumstance does your computer not turn on? Have you disconnected the cable form the motherboard?
by
Yes. I have disconnected the other ends of those two cables from the motherboard side also. Currently system not getting powered on both with and without battery.
by
@prabhakarank do you have a display connected via HDMI when you try to power your computer on? Does your computer give you any sign of life?
by
Show 5 more comments
Add a comment
1 Answer
To use it as a desktop, it supports upto 32GB (2x 16GB) RAM, so install compatible ram and make a DIY dock (see DIY perks video) and you should be good to go
As for the broken screen, damaged components are not my expertise sadly, so I can't help you with that
Add a comment
Add your answer
Prabhakaran Karuppaih will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 141
