Shop the Holiday Gift Guide
Kia introduced the second generation (JB) in the early 2005 model year in Europe and for model year 2006 in North America, based on a redesigned platform shared with the Hyundai Accent.
How do I do a auto transmission fluid change
How do I add the at transmission fluid
Add a comment
1 Answer
Most Helpful Answer
Given this is an older car, you can usually fill these from the top as they could be refilled from the engine bay - that said, some early 2000s cars did move to the current drain and fill process where it is done from the bottom.
If you take a look at the SM for your Rio, I did find it has the bottom drain design so you may have to put your car on jack stands and lift it a few inches to get to the drain plug. Here is where it is on yours per the SM:
KIA RIO 2005
KIA RIO 2006
KIA RIO 2007
KIA RIO 2008
KIA RIO 2009
KIA RIO 2010
KIA RIO 2011
In your case, the SM does not indicate how much trans fluid you need :-(. Based on some quick research, it is allegedly 6.4 quarts, but other sources https://Like this Kia Forms post indicates 7 quarts. Your best bet is to measure the fluid that comes out and see, but if my guess is anything to reference the tans is likely 6.4 quarts or 7 quarts.
Score 1
Add a comment
Add your answer
Dante Yang will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 33
All Time: 946
