Why doesn't the PC turn on when I press the power button?
My PC won't turn on even though all the cables are connected to the power outlet.Is the power supply completely dead?
What is the make and model number of the motherboard?
Most likely the PSU is an ATX type so if you have a DMM (digital multimeter) you can perform the paperclip test and check if the PSU turns on and that all the PSU's output voltages are correct.
If the PSU is OK it may be a problem with the Power On button's cable connection to the motherboard or something on the motherboard itself.
Has this PC worked OK before or is this a new build?
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 64
