Apple's smallest iPhone 14 was released on September 9th and comes with a 6.1" OLED display, an advanced dual 12 MP camera system, and a front camera with autofocus. Successor to the iPhone 13.
Where is Bluetooth antenna and can I replace it?
I got an iPhone 14 on eBay with almost unusable Bluetooth connection. If you move iPods more than 2-3 inches away, it’s drops connection. Can’t see any other local devices. I found a replacement Bluetooth antenna online, but no replacement instructions. Oh, the camera had been serviced. Does anyone know where the Bluetooth antenna is? Could the camera replacement have broken the Bluetooth antenna’s connection? Thanks, r
Add a comment
1 Answer
Most Helpful Answer
Yes, the Bluetooth antenna in the iPhone 14 is integrated into the upper antenna flex cable, which is located near the top right corner of the phone, close to the front camera and Face ID components. Since the camera was previously serviced, it’s very possible that the Bluetooth antenna was either disconnected, damaged, or not properly reinstalled during that repair.
Steps to Check and Replace the Bluetooth Antenna:
1. Check for Loose Connections
• Open the phone carefully and inspect the antenna flex cable near the front camera module.
• Make sure it’s securely connected to the logic board.
2. Inspect for Damage
• Look for any tears or bends in the antenna flex. Even a small tear can cause major Bluetooth issues.
3. Try a Software Reset
• Go to Settings > General > Reset > Reset Network Settings to see if that helps.
• Update iOS in case it’s a software issue.
4. Replace the Antenna Flex Cable
• If it’s damaged, you’ll need to replace it.
• Since Apple doesn’t provide official repair guides for this part, you’ll need to find a teardown that covers antenna locations.
Score 1
1 Comment:
It is NOT integrated on the upper flex, it's on the bottom left speaker
by
Add a comment
Add your answer
ralph will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 182
All Time: 2,140
