Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Three second boot loop
Hi there, I have a 14" MacBook Pro (2021) that starts up when connected to charger, but then restarts after 3 seconds, and repeats the cycle indefinitely. When disconnecting the "battery board data cable" it starts up perfectly fine being connected to the charger only.
Is this a clear sign that the battery board/battery is faulty, or could it also be that there is an issue with the main/logic board? I don't want to replace the battery just to find out that there is something wrong with the logic board. That would be very sad.
Thank you!
Add a comment
1 Answer
Most Helpful Answer
Did you review this guide: MacBook Pro 14" 2021 Battery Replacement taking note of the BMU cable connections and the cable it’s self. I’m suspecting you need a new BMU cable as this one is likely damaged.
Battery management unit (BMU) flex cable P/N 923-06765
I would also install CoconutBatteryso you can see more clearly what’s happening.
Score 1
Add a comment
Add your answer
Eric will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 235
