MP3 Switch On/Off Conundrum
This problem relates to a table-top fairground carousel.
The carousel plays music as it rotates and this was provided by a tape unit until 30 years of use saw its demise. I decided to fit a MP3 player that was small enough to fit into the limited space. A suitable music track was downloaded and the unit was tested as working fine. The snag was that the music was triggered by a pressure switch which was impractical for the setup. To overcome this, I cut off the pressure switch and replaced it with a 6V relay. Power up MP3, switch on relay and all will be fine - or so I thought.
If I connect the switch wires directly, the MP3 plays. If I switch it via the relay, there is no sound at all. The relay checks out as working correctly.
Will somebody suggest where I am going wrong or if there is an alternative to a relay? Bear in mind that my electronics knowledge would be regarded as dim by a fencepost.  Help!!
1 Comment:
Hi @oldsteamer
Post an image showing the setup that you've wired so that it can be seen what you're trying to do. here's how on ifixit Adding images to an existing question
by
Add a comment
