Repair documentation for the 3rd generation 11" iPad Pro (model numbers A2377, A2459, A2301, and A2460). Released May 2021.
How to fix lines in screen
These flickering lines appeared at the top half of the screen. It is worth noting that the iPad has a slight bend. Thoughts on a root cause/repair?
Add a comment
1 Answer
Most Helpful Answer
The LCD panel is under tension which can cause odd behavior when the frame is bent. If you can see if you can flatten the case, just be careful as you don’t want to risk cracking the LCD going to far.
Score 1
Add a comment
Add your answer
TYLER GOODWIN will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 267
