Shop the Holiday Gift Guide
Repair and disassembly information for Samsung's flagship S20 FE Android smartphone, released in October of 2020. Identified by model numbers SM-G780F or SM-G780F/DSM
Not charging even after replacing battery, daughter board and flex
As stated, phone wasn't charging so I replaced the daughterboard and battery. Still wasn't charging so I also replaced the flex cable, and it is still not charging. Anything else I can try?
Add a comment
1 Answer
Chosen Solution
check the fpc connector for the flex on the main board, samsung fpcs are known to easily break, check the left side of it
Score 2
1 Comment:
It wasn't broken, but when I pressed on the connection, it began charging. I pressed a little extra hard along the connection and it's now charging, so it seems like the it may be a little "loose" or finicky, but it's working now. Thanks!
by Share
Add a comment
Add your answer
Terranq will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 20
All Time: 309
