Shop the Holiday Gift Guide
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
X button sticks slightly
X button is harder to press and stays down for half a second, took it apart and cleaned it with isopropyl. Worked great until I used it for about an hour. Same problem, cleaned again. Working for now but I need a more permanent less time consuming solution.
Add a comment
1 Answer
Most Helpful Answer
Hi there!
Yeah, cleaning is basically the solution for this. However, if the issue remains after cleaning, then you might want to replace some components.
I would replace the “X” button and the rubber pad as well. Replacing those should deal with the sticky button right away.
Score 1
3 Comments:
Thanks I'll try that. What's a good brand/website for those components?
by Share
You can find the parts on AliExpress!
Some examples:
Buttons: https://www.aliexpress.us/item/325680635...
by Share
Rubber pads: https://www.aliexpress.us/item/325680437...
Good luck with the repair!
by Share
Add a comment
Add your answer
Topcat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 619
