The TCL 30 XE 5G is a smartphone produced by TCL Communication, a Chinese electronics company. It was first released in 2021.
Phone mic is not working
When I make a call my reciptant can't hear me.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @isaacroawe
Can you be heard OK on a call when using the phone in loudspeaker (hands free) mode?
Is the phone in a protective case at all?
If it is try removing it from the case and check if you can be heard when on a call.
If still no good (and if it is not in a case), try using a vacuum cleaner to clear the microphone voice inlet hole, located on the bottom edge of the phone on the left side of the charge port. Sometimes the inlet hole gets blocked with lint and dust. Do not use a pin or metal probe to try and clear it as you may damage the microphone, which is directly behind it.
If still no good then the phone will need to be opened and further tested as to what is wrong.
Score 2
2 Comments:
How to open this phone?
by
Add a comment
Add your answer
Isaac Roawe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 133
