The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
I think problem in motherboard how to resolve it
I have replaced my note 8 batteries at least 3 to 4 Times ,but it breaks my back panel and got fatty. It automatically switch off while using and when I turn on this handset ,it shows 0% battery and switch off again. It can be a motherboard problem- if yes then how to resolve it
Add a comment
1 Answer
Chosen Solution
If your phone suddenly switches off while using and then shows 0% battery when you turn it back on, immediately switching off again, the most likely culprit is a faulty or worn-out battery, which is no longer able to hold a charge properly and is likely nearing the end of its lifespan.
A few reasons why this might be happening:
  • Degraded Battery
  • Battery Damage
  • Loose Connections
Score 1
Add a comment
Add your answer
Parvinder General Store will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 88
