Shop the Holiday Gift Guide
Presented at the April 2003 New York International Auto Show, for the 2004 US model year, the Prius was completely redesigned. It became a mid-size liftback, sized between the Corolla and the Camry, with redistributed mechanical and interior space significantly increasing rear-seat legroom and luggage room.
ABS light has problems
Score -1
Add a comment
1 Answer
Most Helpful Answer
Herold, as bill was trying to say in his own inimitable way, you have't given us enough information to figure out what's wrong with your car, let alone come up with a fix.
What do you mean when you say the ABS light has problems? Are you just saying the ABS light is on? Or do you mean the ABS bulb is out? As you can see, with only the four words you said, we can't possibly know what the problem is.
If the light is on, you will need to get the ABS system scanned with a reader that can access it; a standard OBD-II reader won't be able to, so as much as I hate to, I would suggest going to a mechanic for a diagnosis. Wheel speed sensors are a common problem with ABS systems, but certainly not the only one possible, so a scan is essential for the proper diagnosis.
Update (01/23/25)
I might add that this is something that is important for you to do, being a safety feature of the car. Your Anti-Lock Braking system will not function as long as the light is on, and if your car is equipped with traction control, that will be disabled as well.
Score 1
Add a comment
Add your answer
Herold Pierre will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 174
