The Dell Inspiron 15-5593 belongs to the Inspiron 5000 series which Dell released in 2019 as a mid-range laptop. The laptop provides 10th-gen Intel processors and RAM/SSD upgradeability and a 15.6-inch FHD display for work and educational purposes and right-to-repair maintenance. The laptop exists under two product names which are P90F and P90F002.
How do I repair a broken hinge?
One of the monitor hinges is broken. I am unsure if it is a hinge pin or if the hinge has disconnected with the base. Do you have a repair guide and repair parts?
Add a comment
Chosen Solution
No guide for this as yet, here's the service manual, my be helpful: https://dl.dell.com/topicspdf/inspiron-1...
Have to work out what's broken - top cover/bezel, bottom case, etc
Depends on the design and the damage, I guess, but typically lugs break on bottom case/top case or top cover, so I'd start with removing back and checking for damaged lugs for the hinges on top-case or bottom case, then go to display assembly - page 41, to see if damaged lugs in top-cover, or wherever.
Score 2
Add a comment
See image content:
Add a comment
Add your answer
Dude will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 21
All Time: 224
