Replaced Battery and Docking port
I ordered an new Battery and a new docking port for my old iPhone 3G. Followed the repair manuals as best as i could. Once it was all assembled went to test it out and let it charge. After charging for an hour went to turn on the device, it acted like it was going to boot with the apple logo and then it went blank. It would only get that far if it was directly plugged into a wall otherwise it would not even attempt a boot up. I assumed it was an issue with the docking port i put in, so i took it all part again and redid the entire thing and still nothing works. I have no idea what could be the issue here. Any help would be awesome.
2 Comments
Does it charge while plugged into an AC adapter? Why did you change the battery and dock connector? What happened that made you change it?
by oldturkey03
The port for the docking connector was broken and took some work to even plug the phone in and when it did charge the battery would not hold the charge for long even after a fresh install with nothing running that would soak up that much battery. And no it does not seem to charge while on the AC Adapter, the phone is currently off and does not appear to charge.
by legibryn
