Repair, disassembly, and troubleshooting information for Apple's "smaller" 2023 flagship smartphone, released September 22nd. It features a 6.1" ProMotion OLED display, a triple-lens rear camera system, and 5G. Successor to the iPhone 14 Pro.
Camera won’t calibrate
Camera won’t calibrate. Keeps saying no objects found, restarts camera & goes back to finish repair.
Score 1
2 Comments:
You probably have a ripped camera flex or some dirt between the connectors. You could try to disconnect the cameras again, clean the connectors with some IPA and reconnect. Be sure to check the flex cables for rips or hard fold lines.
by
Camera was cleaned & checked, not sure I want to go to the trouble of opening it again. Camera works fine just won’t calibrate
by
Add a comment
Did you use an original part from Apple? As long as you see an preview, when you do the calibration, make sure there are objects within your surrounding. This can be items on your desk or furniture in the room. This proces can be a bit long but just keep turning the phone until is says finished. Hope this helps.
2 Comments:
The camera was purchased on ifixit, when I do the calibration it says Apple part . I’ve made sure there’s objects in view, it doesn’t recognize them & they are large objects. I get the same message over & over. Then it restarts & the same message appears that I need to restart & finish repair . I’ve tried this many times & it just won’t calibrate.
by
I took my camera to a repair business and now mine is getting the same message. The camera works great just can’t seem to locate item to calibrate on.
by
Add a comment
From what I have found is the Lidar needs to work correctly to calibrate.
Have you swapped the back glass?
Poor quality back glass panels have a black spot for the lidar sensor. this doesnt let the lidar function correctly. You need to ensure you have the pink reflective coating on the hole. Shine a light through and it should be red.
I had the same issue, unable to find object. I sourced an OEM back glass replacement and it worked. I also used a genuine apple camera also used. After the new back glass was put on it still gave me a error but on the second attempt after using the lidar for measuring function it worked.
Add a comment
Add your answer
Hairstylistroxx will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 61
All Time: 941
