Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
Trackpad and keyboard both not working - MacBook Air A2179
About two months ago, both Trackpad and Keyboard have both stopped working on my 2020 Macbook air retina at the same time. At first, the keyboard was acting erratic and the touchpad took a while to respond to my inputs. After closing the laptop and leaving it for 2 hours, both the trackpad and keyboard are no longer functional. I attempted a system update which made everything worse; now instead of going to the login screen, I am prompted with "an update is required to use this startup disk" along with a really slow boot time. I tried replacing the trackpad cable myself but this did not work and the keyboard and trackpad are still not working.
NOTE: device purchased in July 2024 secondhand
Update: I’ve purchased a new trackpad connector daughterboard. Will update once it arrives
Update 4/6/25 - I replaced the daugtherboard and the trackpad cable. Neither worked. Device is still bricked
1 Comment
@grant8248 - What do you mean by Bricked? That implies nothing is working! No display or any response when trying to turn on.
by
Add a comment
1 Answer
Most Helpful Answer
The trackpad cable is a dual use! It connects to both the trackpad as well as the keyboard. Make sure the connection is not damaged on the logic board.
In this series there is also a mid board just above the trackpad which you can see in Steps 8~10 in this guide MacBook Air 13" Early 2020 Trackpad Replacement see if there is any staining or corrosion on it as oftentimes that is the problem. You should review the connections as well making sure the ribbon was fully and squarely inserted before the clamp latch was engaged.
Score 1
2 Comments:
I looked, thanks for the suggestion @danj! Everything looks good and there are no signs of corrosion on the board and nothing appears to be obviously blown up or shorted. Perhaps the daughterboard connecting the trackpad and keyboard is faulty?
by
@grant8248 - Yes, that can happen too!
by
Add a comment
Add your answer
Grant will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 20
All Time: 209
