Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
576 Questions View all
When I plug the AC power I see one LED which is green.
I have the similar problem. When i plug the AC power i see one LED which is green.
When i push the power button nothing happens.
Does it mean that Power Supply is dead ? Or Logic board is dead ?
Add a comment
1 Answer
Chosen Solution
Your symptoms indicate a failed power supply. Please give us the last three figures of your serial number to make sure of which machine you have and to get you to the correct guide.
Use a multimeter and test the output of your power supply.
LED #1 Indicates that the trickle voltage from the PSU has been detected by the logic board. This LED will remain ON whenever the iMac is connected to working AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power source is disconnected or the PSU is faulty. LED #2 Indicates that the main logic board has detected proper power from the PSU when the computer is turned on. This LED will be ON when the computer is turned on and the PSU is working OK. LED #3 Indicates that the computer and the LCD are communicating. This LED will be ON when the computer is turned on and video signal is being generated. Front LED Indicates that the computer has power but no video signal (e.g., the computer is starting up or the display has entered Sleep mode, turning off the video signal). This LED will pulse when the entire system enters Energy Saver mode
Score 2
Add a comment
Add your answer
shashipatra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 261
