A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
USB cable transfer to computer not working
I initially had the problem where it says there is moisture in the charging port
and will not turn on. I took it to a repair shop and he replaced the charging
port board. Then it worked alright for a while but now it has stopped working
when I want to transfer files between the computer and tablet via USB cable.
Windows says the device attached is malfunctioning. The tablet still charges
properly though (and normal charge not slow). So could this be a problem with
the connection between the charging port board and the motherboard or the
USB connector on the tablet? In either case maybe I could just take it apart
and clean it up myself? I have a fairly good knowledge of electronics but not
much experience in maintenance. I would be most grateful for any advice
anyone can give me.
Add a comment
Most Helpful Answer
have you checked that the USB cable is capable of transmitting information and not just current. If there is a genuine problem with the tablet and not the cable you probably need to change the USB port here is a guide Samsung Galaxy Tab A (2019) USB-C Charging Port Replacement
Score 1
Add a comment
Hello there,
Thanks for your input. I diagnosed that it was indeed the table in the end by connecting my phone to the computer using the same cable and transferring files worked. I had the charging port replaced last year by a repair shop and did not want to have to keep doing it as it costs £60 and you can just buy another tablet for that. Similarly doing it myself will cost £30 in tools and a lot of time and effort. Also the last time I did that was taking a PS/3 apart and when I put it back together the WIFI ceased to work! Admittedly now I have found this site future operations should be a lot less hazardous :-)
In the end I had an idea which is to remove the MicroSD from the tablet and plug it into the computer via a USB/MicroSD adapter I had hanging around. It is transferring 30Gb right now and looks like it will finish in 20 minutes: would have taken over a week via Bluetooth!
Anyway thankyou again for your help.
Regards
Score 1
Add a comment
Add your answer
Lori Fairhead will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 16
All Time: 265
