The 2008-2014 (fifth generation) Honda City was unveiled in Bangkok, Thailand in September 2008. In South Africa, the Honda City is called the Honda Ballade.
Why I can't change direction of my AC from Front to windshield?
I am unable to change direction of my AC from front to another direction. I.e from front to windshield, towards downward
Add a comment
1 Answer
Most Helpful Answer
First I would try blowing out the air ducts to make sure there is no debris which can block the doors, but if there is no debris the problem is usually that the blend door actuator is bad. That is what controls the direction of the air flow and I have seen them crack, the shaft that actually moves the doors breaks, or the electronics in them can be faulty if applicable.
Replace that and it should fix your issue.
Score 1
Add a comment
Add your answer
MUHAMMAD SUFYAN TAYYAB will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 81
