Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Install a 4S battery in a 4?
My friend has a 4S and i kinda like the battery life, but I do not want a 4S, mainly because I have a 4, hacked siri on LEGALLY and somewhat successfully, i just need a proxy
I would also like to install the battery from a 4S too, and i wanted to do the camera, but i can't, but i have heard you can do it fine, i need to do more research
is this possible?
Score -1
Add a comment
1 Answer
Chosen Solution
nick, check on the teardown and see what it says "You probably want to know if you can use this battery in your iPhone 4. Sadly, it appears that the connectors are different shapes, so we'd have to say that it's not likely." from here for the camera, count the pins. The iPhone 4s has 32 and the iPhone 4 has 28. You answered this yourself before here. Remember, just because you have read a online statement by someone that "I have done it and it works" does not mean it will work for you;-) get way for more information and question others statement if 100's are saying it can't be done. Sure, anything is possible, but if it involves any kind of mod, then you have to make sure you get all off the info. Hope this helps, good luck to you.
Score 1
4 Comments:
i'm just bummed i cannot do this, oh well, if for some reason a camera is ported, i'm doing that
by
am i even half suprised i cannot do this? no, apple wants to sell me a useless upgrade, oh well to that too, at least i have siri
by
nick, thanks for accepting my answer. I know how it feels. That is the peer pressure that makes us buy a new phone,camera,TV (well you get the picture) :-)
by
i do have the status of running siri on my 4, i did compare the connections, appear similar, it's the screw points that hold it in
by
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 260
