The PSP 3000 was released in the U.S. on the 15th of October 2008.
PSP won't turn on, orange light.
i just recently got a PSP 3000. put memory card and battery in and plugged it in. set it to english from japanese. it worked fine, but then i put an UMD disc in and when i tried to launch it it turned off and won't turn back on. this orange light is on and sometimes when i flick the power switch it briefly turns green, but the screen never turns on. i've tried taking the UMD out, taking the sd card out and taking the battery out. please help me, i just got it :<
2 Comments
Hi!
Is the PSP modded? If yes, you can press and hold “R” and then turn it on. It should launch the recovery menu. Hopefully this works..
by
@dan0
hi, i've tried all kinds of button combos.. my psp isn't modded either, or at least i don't think so. i bought it used on ebay, so im not sure... ive tried button combos and SD card/battery removal but nothing seems to work. :< i think it may be bricked? but i thought it wasn't possible with unloaded systems..
by
Add a comment
1 Answer
Most Helpful Answer
Hi!
When you press and hold the "R" button, it should load the recovery menu (IF it's modded). So, the PSP isn't modded or it is broken.
It could be a lot of things to be honest. Did you contacted the seller on Ebay and explained to him? Best thing is to return it whenever it's possible.
Otherwise you do need to disassemble the device and check if everything is connected properly and check if all the ribbon cables are fine. Also check the UMD drive and the laser. If all looks fine, then you do need to inspect the motherboard and do some measurement to see what failed...
Score 1
Add a comment
Add your answer
sof will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 227
