ELx800 absorbances directly from the instrument
About biotek ELx800 I only want to read absorbances directly from the instrument via a printer what are the instructions
Score 1
Add a comment
@nikolaslavdas this sounds more like a setup question than a repair. I would suggest that you look through the user manual for whatever software your microplate reader is using. Not even sure if you have a printer attached and installed. For that use the operators manual for the ELx800
Add a comment
Use a plain ASCII-compatible printer. USB-only or modern inkjet/laser printers usually won't work unless using a serial-to-USB converter and driver support.
If you're using BioTek Gen5 or KC4 software on a PC and still want to print, the software must support the hardware printer configuration.
Add a comment
Add your answer
Nikolas Lavdas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 100
