Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
Use apple watch series 2 charger on apple watch series 4
I've an apple watch series 4 that I'm actually using. I also have an apple watch nike series 2 that I will need to repair, I've noticed that the charger are similar but not sure if there is any difference. If I use the charger of the apple watch series 2 to charge the seres 4 can be a problem?Can this damnage the device or the battery?
Add a comment
1 Answer
Most Helpful Answer
The charger power output needs to be around 12Watt. The USB-A Puck is the same for the older Watches the newest Watches use a newer USB-C Puck and a newer charger.
Score 1
2 Comments:
Ok, so basically the only difference is with thte USB Puck type that is used, both charger can be used with no problem, right?
by
@ziobru - Not sure you are asking. The USB-A puck is what you watch needs.
by
Add a comment
Add your answer
B1P will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 90
