What are the 3 golden notches inside the watch?
What are the 3 golden notches inside the watch? 2 on the screen side. One from mine got removed, now my sensors are not working. I do not know if that is the reason though. As in my wrist does not get detected, thus the watch automatically locks itself.
Update (10/24/24)
thank you so much for replying instantly, i did not expect that.
https://imgur.com/a/TsCSPdC here is the link to what got removed. I already tried putting it back glueing with B7000 the black underside part of the gold notch.
For context, my watch got damaged by water - stuck in bootloop for weeks. A repair shop said it is a faulty board and they'll try fixing it in exchange for a big amount of money.
I then submerged the watch in 99% alcohol like 5 times until it turned on again. Everything is working fine perfect. and used it for 2 weeks.
However, I'm trying to remove the old adhesive to prepare reapplying adhesive, then the gold notch got removed. After that, the sensors do not work and my wrist is not detected
1 Comment
If you are talking about the SIP module the larger ones in the corners are manufacturing fixture point to hold the SIP during it’s construction and is also a chassis ground point. You really need to post a prober question with a clear picture of the damaged part.
by DanJ
