Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
System Files Are Corrupt
I've gotten into fixing consoles and recently came across two wii's that were broken. One of them I was able to get up and running pretty fast, the other one however is uh, questionable. It's got the dreaded "System Files Are Corrupted" screen, and normally I would be able to access different settings to attempt to fix it. But the previous owner has seemed to try to fix it with a factory reset, sending the wii back to its factory default, and as soon as I try to set it up the screen flashes a little, and then just prompts me with the Corrupted file screen. Even when trying to boot to matienence I get the same issue. So I'm wondering if somewhere out in the wii nerd/homebrewing world if there is a piece of 3rd party software or a random button assignment that would give me some kind of access to any type of settings to try to fix it.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi Jackson!
Please try the following procedure:
Turn on the Wii, now press and hold the reset button imediately after you turned it on. Hold the reset button and hopefully you will get a new screen now “Priiloader”. Stop pressing the reset button.
From here you should boot to the “Home Menu”. You can also adjust the following setting: “auto-boot, to the original Wii home menu”. Please do this, now you should be able to access the Wii again.
Please let us know how it goes!
Score 1
4 Comments:
Hi! Unfortunately this did not work, as it just boots to the regular screen and does the Corrupted screen again, is there any other way? Please let me know.
by
Ah, then Priiloader wasn’t installed at all :(. Is the SD card still there? Or is there no SD card at all? If not, then I’m afraid it’s bricked... You do need to replace the NAND at that moment. Unfortunate it's very difficult to replace it and you need another broken (donor) motherboard with a different issue. The other option left is to replace the motherboard for a working one. This is way easier, but more expensive. The drive it's PCB does not need to be transferred.
by
This actually works for me since I got the same error with or without SD card and I was able to get a game reading and I'm playing it right now with no errors, thank you!
by
My pleasure! Have fun gaming Ezra :)!
by
Add a comment
Add your answer
Jackson Byard will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 120
All Time: 1,875
