The T460 is the standard model out of three laptops in the T460 series, all released by Lenovo in February 2016.
Repetitive crashes and freezing relating to SSD
I've had this laptop for less than a year and I've barely used it. I keep getting these crashes and blue-screens (and occasionally a yellow-screen) suddenly and for no reason. I could be staring at my desktop and it'll hit me with a blue-screen and start beeping. I get an error screen sometimes with the message "Detecton error on SSD (M.2)." Whenever these crashes happen it takes a while for me to boot it back up. It usually forces me to open Lenovo Diagnostics on startup. I tried taking apart the laptop to ensure that the SSD isn't loose. The manual isn't very good so I couldn't even find it. What's my next move?
2 Comments
Hi @thedukkofcode
What does Lenovo diagnostics mentioned about SSD health?
Two possible fault which i can think of.
1. SSD is failing
2. Mainboard having some issues / connector issues.
If it is still under warranty, consider to get check by Lenovo.
by
Thank you for your comment, @salmonjapan
I’ve ran every extended test in Lenovo diagnostics and they all passed. Leaving me even more confused.
by
Add a comment
1 Answer
Chosen Solution
I opened up the laptop, took out the SSD, and placed it back in. Since these crashes were happening multiple times per hour, it’s safe to say the issue is now fixed. Vibrations or dust could’ve affected the connection and reseating it reset that connection.
Add a comment
Add your answer
Dukk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 199
