Repair guides and disassembly information for the 16-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2485.
Display turning off itself
My system fell in water, I took it to a local shop for repair and it was working back but the screen goes off even while working on it. It will only comes up whenever I press any key on the keyboad. This normally happens after the system stay up for like between 15-20 minutes after booting. Please what can I do
Add a comment
Chosen Solution
Since this has a history of liquid damage, it's likely that either a component on the logic board related to display logic is damaged, or a component on the display itself is damaged. I would recommend taking it back to the repair shop to see what they recommend! Otherwise you would need to open it up and inspect components for damage and possibly do some level of board repair. Good luck!
Score 1
1 Comment:
Thank you Zach. I have returned it but the technician said it was a screen. hard to believe because sometimes it work for like 20 minutes before the acting up
by
Add a comment
Liquid damage often effects the battery, have you checked the battery? Install this gem of an App CoconutBattery it will offer you a better view on what’s happening. Post a snapshot of the Apps main window here so we can see things as well.
I would also run the onboard diagnostics restart the system and press the startup D key to enter, did you get any errors?
Add a comment
Add your answer
Athul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 97
