The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
Side panel wont open
The lever on the side of the mac wont come out fully, and because of that i cannot open the side panel. Any tipps to how I can fix this?
Score 1
Add a comment
Chosen Solution
SOLVED! Turns out there was a loose screw stuck in the latches inner part and because of that you couldn’t pull out the latch fully. The solution I came up with was to turn the whole mac upside down dislodging the screw.
Score 1
Add a comment
Is the lock enabled? You could try a little WD40 sprayed into the handle area. Don’t over do it, a little goes a long way.
Add a comment
Add your answer
Mérei György will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 131
