A heat gun is a device used to emit a stream of hot air, usually at temperatures between 100 °C and 550 °C (200-1000 °F), with some hotter models running around 760 °C (1400 °F), which can be held by hand.
Why my heat gun stop and never been worked
After using inco heat gun never been worked like no power
Add a comment
1 Answer
@sydforest could be as simple as a bad connection on the switch. Of course it is also possible that this is a bad switch etc. Time to take it apart and to have a look. Post some good pictures of what you find once you have it opened up. Adding images to an existing question
Add a comment
Add your answer
Syd Forest will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 181
