The M2 is Apple's second iteration of their System on a Chip for Mac, featuring integrated GPU, CPU, RAM, and other components for improved performance and efficiency. The base M2 in the Mac mini has an 8-core CPU with four high-efficiency cores, four high-performance cores, and an integrated GPU with 10 cores. Identified by model number A2686.
Can I make my Mac Mini M2 transparent?
I was thinking of maybe buying a base-model M2 Mac Mini solely for the purpose of making it transparent. Would this be possible though? Also, what would I have to order to make this happen.
Add a comment
1 Answer
While one could CNC a block of clear acrylic emulating the case, you shouldn’t run the system that way as the metal case suppresses the EMI noise which can effect other radio signals like Bluetooth,WiFi, TV over the air and cellphone service. While you might not be bothered your neighbors might.
Add a comment
Add your answer
ParkerE1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 85
