Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
PSP detects select and analog when not pressed
As the title says, the console detects that the select is being pressed and the analog moves down without being connected. The console only turns on if the select is held down, just like the rest of the buttons only work if the select is held down. It also happens, that if I release the select, the console stays on hold. Sometimes when I press a button and release the select, the button stays pressed. I have replaced the flex with a new one but the problem remains and even if the flex is not connected the console still detects it.
Score 1
Add a comment
Chosen Solution
As I specified in the comment of the other answer, what has partially solved the error and has allowed me to use the buttons without the select has been to clean the motherboard of the embedded dust that was on the back.
Although I can use the console, it still detects that the button is still pressed, it may be because I have only cleaned it without isopropyl alcohol and just gently brushing the board.
I leave the link where I found the answer, in case someone has a similar problem with other buttons, since it does not necessarily have to be in the same buttons.
Lastly to keep in mind, it is likely that if after cleaning with isopropyl alcohol the problem persists, it may be due to a short in the plate. For my part I can't check that as I don't have the tools or the knowledge to see where it may occur.
Specified link
Add a comment
Most Helpful Answer
Hi!
This is a strange issue! I recommend to replace the “start, select button bar with cable”.
This should fix it.
Please try this first, and please let us know how it goes!
Score 1
2 Comments:
I did the replacement, but unfortunately it didn't work. I have read that it could be some dust on the motherboard probably shorting out. By and by I didn't see anything from the front, but from the back it had a little dust accumulated in one particular area. Now the console turns on without pressing select, but when I enter to modify the name it still detects that the button is pressed. Due to testing, I installed the official firmware, so I have to redo a custom firmware installation and run the key tester. I will do an update later.
by
Hi! Alright, didn’t heard about this before! Glad that you were able to fix it :)!! Thanks for sharing the answer with us!!
by
Add a comment
Add your answer
hardcode will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 442
