Jumping x battry to the motherboard
Please how can I jump my iPhone X battery terminals to the motherboard using jumping wire buy using only positive and negative terminals?
I haven't got my set of schematics downloaded to my personal computer yet, so I can't give you specific directions for that at the moment, but if need be I'll see if I can get to that soon.
However, one thing to be aware of is that if you don't have the battery connector plugged in, your phone will be missing the battery temperature and voltage sensors, which will result in a three minute boot loop cycle. That means you'll only have three minutes in which to use the phone before it reboots, so it really depends on what you're trying to accomplish as to whether bypassing the battery FPC connector is worth your time.
So maybe if you explain what's going on and why you want to jump the power connectors we would be able to give you better advice.
My batery clip is bad i need to do the jumper
@danielokafor Again, without the extra data lines connected, your phone is going to automatically reboot every three minutes. A much better solution would be to replace the connector on the motherboard (assuming that's the one that's bad). It does require some amount of specialized skills, but a competent repair shop should be able to fix it for you if you don't feel comfortable attempting the repair.
Why don't you start your own question and add some pictures of your damaged connector and perhaps we might be able to make some better suggestions for how you can make your phone usable again.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 116
1 Comment
well why would you need to do this?
by Hampter
