How can I fix horizontal lines on my Philips screen?
I have a Philips 58PUS8545/12. It is about 2.5 or 3 years old.
Just a month or two after warranty expired, I started getting display freezes of one part of the image. The bottom part. Here’s a video for reference.
This issue came and went. But it was starting to get really annoying with increased frequency of occurrence.
I spoke to an electrician store, he told me that this is a common problem with newer Philips TVs, and that the T-CON board needs replacing. However, since they don’t sell these parts individually here, he advised me to just buy a new tv.
I looked up the t-con board model (CCPD-TC575-009 v1.0) and I found it on eBay. I ordered one and when I tried it (using the new connector cables they provided), it didn’t work. I thought it was hopeless. However, a couple of weeks or so later, I thought I’d try again, and this time I used the old original cables. To my surprise, it worked!
The screen wasn’t frozen any longer, however, there were horizontal lines in the same area where it used to freeze. These lines came briefly and went, but a couple of days later and they completely went away!
Fast forward to a month or two later, the lines came back, but this time they stayed and they never left my display since. Here’s another video for reference.
I checked the left and right cables connected to the board. The problem is definitely coming from the right side, as when only the left cable is connected, the half-image looks perfect (apart from the color being slightly dull), but when only the right cable is connected, the lines are back.
Interesting note is that when I tried connecting the board one time, I did it with the right cable being the other way around than it originally was. I thought this shouldn’t matter, but there was no image whatsoever then. The image returned (with the lines) when I inverted the right cable again.
Can you please help me fix this?
Thanks very much for taking the time to read my post, and sorry for the long explanation.
Update: here are photos of the three main boards on the back
3 Comments
Hi, my philips LED TV 65 inches is wall mounted. Must i remove from the wall to do this checking of the ribbon? Thanks
by Mogana
@mogana hey! Unfortunately, it’s a must to unmount the tv in order to unscrew the back side and uncover the cables. Unless you have Mr. Fantastic flexibility and especially maneuverable tools that fit and operate through crack openings, there’s no other way
by Samer Shaheen
i bought a new tcon board but the same vertical lines no picture
by Mike Kansen
