air bag code 2295 07 milan
2295 rt ft air bag do i start checking rt ft seat conectors or air bag itself .
The RCM checks all of the seat side air bag circuits for faults. If the RCM detects one of the following faults on any of the seat side air bag circuits, it will store diagnostic trouble code (DTC) B2295 in memory and flash either lamp fault code (LFC) 22 or 23 depending on the fault (or higher priority code if one exists) on the air bag indicator.
Fault Conditions
alan, check this:
The RCM monitors for the following fault conditions:
Low resistance
High resistance or circuit open
Circuit short to voltage
Circuit short to ground
Possible Causes
A seat side air bag status fault can be caused by:
wiring, terminals or connectors.
a faulty seat side air bag module.
a faulted RCM."
Hope this helps
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 9,014
