7 MP camera with 4x optical zoom.
2 Problems: No image on the LCD and Memory Card Error
The A620 I bought at auction looks brand new but it has 2 problems. With fresh batteries, I turn it on, the lens comes forward, and when I open the LCD screen there is no view, but the display items show up, such as the L and P etc. so the LCD is ok but I can't see the subject through the lens, just black. On the top of the screen it says 'Memory card error'. I have tried 3 different SD cards and the message stays the same. When I push the Menu button and get to settings, the Format... selection is black and I cannot choose it to format the card. When I push the shutter button the camera makes little click sounds and no photo is taken. If I toggle the playback switch, it also says Memory Card Error and 'Card Locked!' even though the card is NOT locked. I tried 8, 16 and 64 gb sd cards.
2 Comments:
When I remove the sd card, the camera operates and seems to take a photo, but still nothing shows up on the lcd screen. I'm going to buy an older non-hc sd card, since I saw another posted answer saying that this generation of camera does not like HC type of cards.
by
Does anyone know where to get parts for this camera? I searched the internet and no results come up, and I think it's too obsolete for professional repairs. One repair place said they can't get parts for it. A new 2mb sd card fixed the card error, but still no image shows on the LCD.
by
Add a comment
1 Answer
@charlesmye74083 problem number 1 seems to be related to either a bad lens shutter or the image sensor. Number 2 appear to be your memory card ready. It may just be time to take it apart and have a look at those things. I would use these guides Canon PowerShot A620 and this Canon Powershot A610 A620 Parts to work on it. See what you find out. If you are stuck anywhere , you can always post some pictures of it with your Question. that way we can see what you see.
Adding images to an existing question
Add a comment
Add your answer
Charles Myers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 206
