An Uninterruptible Power Supply (UPS) is an electrical device that provides backup power to critical equipment in the event of a power outage or other power-related issues.
Check the correct functioning of the PCBA
Lately I can't see anything in the ViewPower program and when I contacted BlueWalker support they told me that the problem is the PCBA.
How can I check it to see if it really isn't working?
UPS Model: PowerWalker VI 1000 PSW Schuko
Update (09/08/24)
I have this:
How do I add port to Firewall exclusions in Windows 11?
In order to start, the following screen must appear:
How can I start it automatically?
I solved the problem.
Add a comment
1 Answer
Chosen Solution
Hi @piero90
If you haven't already done so, here's the S.O.P. How To Check ViewPower Status And Open Port guide that may help.
Score 2
10 Comments:
Thanks for the guide
by
@piero90
Did the problem only occur after you updated to Win11 (if you did) or not?
Here's a video that may help.
by
I followed the video but nothing
by
@piero90
if the port is "open" and there's no connection with the UPS then most likely it is the UPS unless it is in the wiring/cable etc between the UPS and the PC
by
I must try to change the cable to verify if the problem is UPS
by
Show 5 more comments
Add a comment
Add your answer
Piero Sabino will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 368
