The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
GameCube suddenly stopped working
When I turn it on , only the fan works with nothing else
i think it's because i tried to turn on a wii u with the gamecube's AC adapter
Add a comment
1 Answer
Most Helpful Answer
Hi!
So you used the GameCube it's power supply on the Wii U?
The worst case is that your Wii U took damage or the power supply.
I would try a new power supply and see if this fixes it for your GameCube!!
If not, then you probably need to inspect the motherboard and check the caps.
Also check the power board and replace if needed.
Part: https://www.ebay.co.uk/itm/194935186310?...
Please let us know how it goes!
Score 1
Add a comment
Add your answer
Titan will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 49
All Time: 172
