Power button Not work
I want to change my power button
Add a comment
1 Answer
Okay
Here’s some info for other possibilities check first.
https://www.getdroidtips.com/guide-to-fi...
IfIXIT doesn’t seem to have a guide on this model currently . It’s a about a 6/10 difficulty I’d say. Easy if you take your time .
The switch Under the button is the likely issue. Not the button itself.
Here’s a replacement switch cheapest I could find. You can look it up on other sites. Just check it’s the same one.
https://www.aliexpress.com/item/10050038...
Here’s a guide play it slow a few times to get the idea. It’s pretty easy if you take your time.
https://youtu.be/diPz_m5H7lI?si=n_X5qUui...
1 Comment:
If you decide to do this why not replace battery at the same time? https://www.aliexpress.com/item/10050076...
by
Add a comment
Add your answer
Sanskar Upadhyay will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 7
All Time: 156
