The Xiaomi Redmi 7 is a low-budget smartphone by Xiaomi released March 2019. It has a 6.26" IPS LCD display, a 12 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 632.
My phone is working when it is on chargeing
Add a comment
1 Answer
@honeysingh38432 I assume that what you are not saying is that it does not work when it is not plugged in to charge. In that case, replace the battery and re-evaluate after. While you replace your battery, check the charging board and the flex cable connecting the charging board to the main board. Make sure it is seated properly and has no tears etc.
Since iFixit does not yet have a specific guide for this task, use the one from here It was written in Spanish so use a web browser that does the translating for you, if needed.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Add a comment
Add your answer
Honey Singh (8th C adm:8434) will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 64
