Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Question Closed
Because the bluetooth device is not available?
Simply the bluetooth device stopped working, I can not find it I tried to perform a scan with Apple Hardware Test is not possible for him to be with icompatível updated version of the Lion. And now what to do?
Add a comment
1 Answer
Chosen Solution
it due to the losse connection of wire to logic board jack. try to reconnect the cable coming from display clamshell to logic board . its the only wire which is so long as compare to others in the laptop. remove it then put back in then check . if working then it good otherwise . have to remove the display clamshell and remove that black strip from the display . there is wifi and blutooth card. check the losse connection there .
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 706
