The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
308 Questions View all
Question Closed
Moding my xbox with a clear case.
Hello.
i am putting a clear case on my Xbox 360 s console and i wanted to no do i need the thin aluminum sheet attached to the plastic on the inside of the case. It blocks a lot and kinda destroys the idea of a clear case..please answer
-Kaine
1 Comment
Thank you and i have seen them ran without just so you can see inside them?Any thought about this??
by
Add a comment
1 Answer
Chosen Solution
kaine, there is a lot of sheet metal attached. I would think that this is responsible for airflow, EMI shielding, and possible structural stiffness. It might even provide a common ground. I guess you can always try to run your xbox without it and see if it overheats, and if you will have interference from, and to, other electronic components. Hope this helps, good luck
Score 1
1 Comment:
+1. Also, I take the mod case comes from a reputable source. They usually add a manual, telling whick parts salvage from the old case and which keep.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 845
