The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
cartridge push in wrong way
cartridge push in wrong way flashes then off how to fix
1 Comment
Could you take a close up picture of inside the cartridge slot.
by
Add a comment
1 Answer
Most Helpful Answer
Hi!
First things first, the cartridge need to be removed first. Be really careful with this. Also first remove the back cover so that you can also pry to remove it from below. When the cartridge is removed, please check for damage. If some pins are bent or broken, you probably do need to replace the game card reader. Hopefully this is not needed as you do need to solder it out, this can be somewhat difficult...
But, like Daniel said, some pictures would be nice, if possible!
Score 1
Add a comment
Add your answer
jayeim smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 73
